disable learning vxlan ipaddress
disable learning {forward-packets | drop-packets} vxlan {vr vr_name} ipaddress remote_ipaddress
Description
This command disables learning a remote endpoint.
Syntax Description
forward-packets Forward packets with unknown source MAC addresses.
drop-packets Drop packets with unknown source MAC addresses.
vr VR/VRF instance the IPv4 address is configured on.
vr_name An existing VR/VRF name.
Default
N/A.
Usage Guidelines
N/A.
To disable learning on a remote endpoint:
disable learning vxlan ipaddress 1.2.3.4
This command was first available in ExtremeXOS 21.1.
Platform Availability
This command is supported on the ExtremeSwitching 5320, 5420, 5520, and 5720 series switches, and stacks with 5320, 5420, 5520, and 5720 slots only.
